Car dies when driving
Old Jul 3, 2015 | 03:32 PM
86Base's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 383 Stroker
Transmission: stage 2 2004r
Axle/Gears: 3.55
Hi,
My friend and I just finished my engine swap in my 1986 Camaro. We swapped the 2.8 Maf to a 355 tpi with speed density. I went out on my first drive to the gas station and back. About halfway back it died coming to a stop at a light and wouldn't start after like a dead battery. I jumped it and hauled *** home and put the battery on a charger but the voltmeter said it was 12.6 volts. I charged the battery and took it to advance auto parts and they said it was fine. I put it back in my car and checked the voltage and it was staying steady at 12.8 volts. I started the car and checked the voltage when it was running and it was staying at 14.3 volts. Any idea what's going on?
Old Aug 17, 2015 | 04:01 PM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: Car dies when driving
Check the wire from the starter that feeds the fuse block, if it's corroded through it will cause intermittent electrical problems. This one wire feeds 95% of the electrical system in the car.
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 17, 2015 02:00 PM
