odd and random code 44
Old Jul 17, 2015 | 05:54 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
ok, my 86 MAF car runs well , mostly. no CEL and drives and behaves normally , but lately i have been geting a code 44 lean condition. ill be driving along and feel a "stumble " and the light will come on . 44 is the only code stored too. its an intermittant code because it will go off and on . during the drive. and having followed the trouble tree in my FSM . everything checks out. no FPR issues. proper fuel pressure. no vaccum leaks . (it idles at 17 inches). AND no matter how many times i set the minimum idle air and TPS. (as per FSM). i cannot get it to stay idling at 750 in drive , all will be well at first but eventually after several days the idle speed will be back around 1500 RPM. all wiring, sensors and relays are proper, and new correct parts . it has the usual 7165 ECM and the PROM i got from brian last year. damn , im stumped !! any one with any ideas ?
Old Jul 17, 2015 | 04:36 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: odd and random code 44
I'd check the o2 curcuit. http://chevythunder.com/o2_sensor_code_44.htm Beyond that...what injectors do you have? Are they new/newish?
Old Jul 17, 2015 | 09:49 PM
Car: 86 IROC
Engine: 5.0 TPI
yeah i replaced them all and the FPR too almost 4 years ago. and as for the o2 sensor . i guess it could be bad . but it too was replaced not even a year ago during a major tune up
Old Jul 17, 2015 | 10:39 PM
I wouldn't just condemn the sensor. I'd suspect the circuit as a whole.
Old Jul 19, 2015 | 05:04 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Code 44 is a real PITA, I fought it for months, replaced my egr and it went away for a couple months, then it came back and ended up being a vacuum leak at the throttle body. Check for vacuum leaks first things first, that also ties into you not being able to achieve the desired idle.
Old Jul 19, 2015 | 07:25 PM
Car: 86 IROC
Engine: 5.0 TPI
i was thinking that too . until i put a vaccum gauge on it , idle its 17 inches. no way it could be that high with a vaccum leak ??? and my EGR valve is new as well. so ??
Old Jul 19, 2015 | 07:35 PM
TylerSteez's Avatar
Engine: 383 stroker
I'm not too sure about vacuum measurements, I just puffed on a cigar and blew it into the vac lines until I found all my leaks. And if that's the case then I'd start looking at the O2 sensor. It's been a while since I've went through my code 44 hell so I'm sorry I can't offer you any more info. I remember heavily researching it at the time
Fanatic1074
Oct 3, 2022 05:57 AM
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Luigytico09
Oct 1, 2015 08:46 AM
