HELP! Crankcase Ventilation Tube/Hose Replacement
Old Jul 23, 2015 | 11:25 PM
1992 Trans Am's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
Hello People! I was changing a bunch of hoses on my 1992 Trans Am (5.0 TPI 5 speed Convertible), and I removed the Crankcase Ventilation tube (the tube/hose that connects on the passenger side of the throttle body and draws fresh air into the right/passenger side valve cover. The crankcase ventilation tube cracked when I removed it. I cannot find a replacement anywhere (NOS or aftermarket), and I need to keep it hooked up for CA smog requirements. Anybody deal with this issue? Curious what remedies or solutions you all have found in order to replace the tube when it dries out and cracks. OR Ideally, does anyone have a NOS one that they would be willing to sell? Please let me know your thoughts, solutions and remedies!
Old Jul 24, 2015 | 09:59 AM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: HELP! Crankcase Ventilation Tube/Hose Replacement
I've seen used assemblies for sale on Ebay once in awhile. You'll have to experiment with search terms to find it though.
Old Jul 24, 2015 | 11:22 AM
Abubaca's Avatar
Well you can always just use some vacuum line, although it doesn't look the best, or....order part number 10055872 from GM parts direct. I actually just placed an order for that very part!!!!!!! You can ebay search to see a picture, but GM parts direct has it much cheaper. It's a corvette part number, but can't see any real difference from my old cracked part. The most important part for me is the throttle body side, with all the proper bends to fit nice and neat. Worst case if the line to the valve cover isn't 100% the same (not sure why it wouldn't be) it's easy enough to fab/splice up. That throttle body side of the hose is what I want to look nice and factory.
Old Jul 24, 2015 | 11:50 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Gmpartsgiant has it too. Ordered one last week.
Subtotal
$11.31
Tax
$0.00
Best Standard Delivery
$8.18
Total
$19.49
Old Jul 24, 2015 | 01:00 PM
Abubaca's Avatar
OK, mine was $25 out the door, so you got a slightly better deal. I'm not sweatin' the $6 bucks though!
Old Jul 24, 2015 | 01:23 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
LOL! I was just happy to find one. My old one where it attaches to the TB was cracked and wouldn't stay on.....a hose clamp on it looks kinda "rural"...if ya know what I mean!
Old Jul 24, 2015 | 01:34 PM
Abubaca's Avatar
LOL, yeah, what I found that worked real well was to smear some RTV around the nipple on the TB, then use a black zip tie. ....unfortunately it just kept cracking farther and farther down. I currently have some generic vacuum line in place, but hope to have the proper hose on in a few days.
Old Jul 24, 2015 | 03:06 PM
Axle/Gears: 3.08
I just ordered GM p/n 10055872 from GM Partsgiant for $20.39 shipped to my door. The bends from where the hose attach to the throttle body look identical to my original hose. The only difference is that the hose length to where it attaches to the black plastic piece that fits into the grommet on the front of the passenger side valve cover is longer, so I think I'll be able to modify it to work on my application. Will post pictures of my original hose, the new one and what it looks like installed on my car. Thanks for the feedback guys! It is much appreciated!
Old Jul 24, 2015 | 03:20 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Parts Giant and Parts Direct are saying...."wonder whats going on over there at 3rdGen? We sure are having a run on these hoses!"
Old Jul 24, 2015 | 03:25 PM
Abubaca's Avatar
Agreed, it would be easy to modify.....but why would it be different? Maybe the difference between the vette magnesium valve covers? I mean they're both TPI small blocks...shouldn't be MUCH difference, right?
Old Jul 24, 2015 | 09:31 PM
Axle/Gears: 3.08
Haha Bob! That's funny! I think that the hose length is different is because the grommet on the valve cover might be at the back of the valve cover closer to the firewall and in late 1989-1992, f bodies have the grommet on the valve cover at the front.
Old Jul 25, 2015 | 09:23 AM
Abubaca's Avatar
Mine is at the back. ....checked a bunch of pics, and from what I can tell, they're all in the back. My factory 89 VC's have the Passenger side PCV tube close to the firewall, and the driver side vent tube towards the front, which would make sense, since it's the same valve cover, so no matter which side you put it on, the hole location wouldn't change. PS back. DS front. Now I currently have aftermarket valve covers, and they're set up to put whatever vents, valves, caps, breathers wherever you want. ...but stock....pretty sure it should be towards the back on the PS. Again....won't affect anything, but for the record...
EDIT- so my car is a MAF car. Apparently after some research...the SD 91/92 cars have the tube towards the front. Yes??? Anyhow...ya learn something new everyday. AGain....shouldn't matter though.
Old Jul 25, 2015 | 11:00 AM
Axle/Gears: 3.08
So it is my understanding that earlier third gens had the grommet on the valve cover toward the back of the valve cover on the passenger side where the crankcase vent tube would attach to, but at some point during the late production months of 1989 GM moved the grommet to the front of the valve cover closer to the throttle body. Has anyone else heard this or something different?
Old Jul 25, 2015 | 11:10 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yup, I think it was changed when they went to SD motors. The oil fill on the driver side was moved to the front (easier to fill oil) and the pass side vent tube was also moved to the front of the valvecover.
Anyone have the PT number for the PVC hose?
Old Jul 25, 2015 | 03:41 PM
Abubaca's Avatar
For the later years up front? Nope, sorry.
Old Jul 30, 2015 | 10:58 AM
Abubaca's Avatar
soooooo.....for the record, both "parts direct" and "parts giant" have told me that they do NOT have any more in stock. Assuming you guys have found the same???
Old Jul 30, 2015 | 11:03 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Got my notice this morning!
Hello Robert,
Thank you for ordering parts with us.
We are writing to inform you that order G627645 has been voided. Your order has been voided because of the following reason(s): The ordered part(s) have been discontinued (no longer available) and/or is backordered with no ETA date by the manufacture.
If you have further questions, contact us.
Regards,
Customer Service
GMpartsgiant.com
Old Aug 2, 2015 | 10:57 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Not surprised to see those two sites send those emails lol. I must have gotten that same email over ten times from them. Not their fault they can't get the part but they should note that its discontinued before purchasing.
Old Aug 2, 2015 | 03:22 PM
chubsworth's Avatar
I had the same issue and couldn't find the OEM part anywhere. Here's what I did. I bought a length of 3/8 fuel hose. It fit perfectly on the valve cover grommet but the throttle body nipple is slightly larger in diameter. So I wedged a ratchet handle into the end of the hose and let it sit a couple of days to stretch the rubber. After that, with the help of a little grease, the 3/8 hose went on the TB fine. Then secured it with a hose clamp. Total cost was $3.
Old Aug 2, 2015 | 06:11 PM
Abubaca's Avatar
Yeah, I KNEW the part was discontinued, but the fact that they allowed the purchase (in my opinion) suggested they had stock. Obviously not. Lol.
Yeah, I did basically the same thing. The issue is appearance. And to be fair, not everyone cares, but I do. The factory piece bends and twists just right through all the sensors and electronics.
Old Aug 3, 2015 | 09:05 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I think what I may try is get a length of vacuum hose, stick a stiff wire in it, say like a coat hanger or something and bend the new straight hose to the originals shape. Might work, but might collapse at the sharp bends. IDK
Old Aug 3, 2015 | 09:37 AM
TTOP350's Avatar
That is a great idea but some of us need a NOS hose for the correct look.
Old Aug 3, 2015 | 09:45 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
That's what I'm after...the correct look.
I am on a quest to find one or more.
Old Aug 3, 2015 | 10:09 AM
TTOP350's Avatar
I need 2 myself..
Old Aug 3, 2015 | 10:19 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
OK GUYS, Brocks Camaro has 1 more that are the long style 1988. I bought one, they have one left as of 10:17am CDT 3 August
http://www.ebay.com/itm/88-early-89-Z28-TA-88-91-CORVETTE-TPI-CRANK-CASE-VENT-HOSE-PCV-RH-PASSENGER-SIDE/371261970048?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D32832%26meid%3D00114e07e47a44a69f79391563d71535%26pid%3D100033%26rk%3D1%26rkt%3D4%26sd%3D371261970048
Old Aug 4, 2015 | 07:50 AM
Abubaca's Avatar
Ummmmm, about that last hose.....not anymore. Bought it yesterday.
Old Aug 4, 2015 | 07:53 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Just kinda pricey though. Oh well!
Old Aug 4, 2015 | 08:31 AM
Abubaca's Avatar
I just bought new heads, so an extra $25 for that hose doesnt seem so bad!
Old Aug 4, 2015 | 03:52 PM
Axle/Gears: 3.08
Original Crankcase Vent Tube. It is cracked where it fit onto the fitting connected to the throttle body.
Here is GM Part Number : 10055872
The original hose vs the NOS GM hose. The difference is that this NOS one (p/n 10055872) is longer, for earlier TPI cars that had the CC Vent Tube connection at the rear of the valve cover. The most important thing is that the curves are molded exactly the same and the throttle body side has a larger diameter than the end where the fitting connects the hose to the valve cover fits.
I measured the old one vs the new one and cut off the end. Be sure to cut off the end that is the smaller diameter for cars that have the fitting at the front of the valve cover like my '92 does, and the larger diameter end is the end that fits onto the throttle body fitting.
Here it is, installed. It fits perfectly and looks exactly the same, which was important for me as I am trying to keep my car extremely authentic original/NOS GM.
Old Aug 4, 2015 | 04:33 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Looks great! My long one is on its way,,YAY!
Old Aug 4, 2015 | 04:47 PM
Axle/Gears: 3.08
Thanks, Bob! I am just happy that all 3 of us were able to find one, and that after cutting off the excess hose, it looks and fits exactly the same as our original cc vent tube (GM p/n 10105287) did! Let me know how yours all work out! For reference, my car is a '92 Trans Am convertible, speed density car, with a T-5 manual transmission, with the crankcase vent tube inlet at the front of the passenger side valve cover.
Old Aug 4, 2015 | 05:42 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I will. Mines the 88, I won't need to cut mine
Old Aug 5, 2015 | 01:11 AM
Axle/Gears: 3.08
Let me know how it works out. And try to post a couple pics if you can, so other members can see the difference in fitment between earlier and later setups of this part!
Old Aug 5, 2015 | 03:23 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Need a long one here.. looks like I am late to the game!
Old May 4, 2016 | 10:49 AM
Axle/Gears: 3.08
Is anyone still looking for one of these? I just got an extra nos one...
Old May 4, 2016 | 12:27 PM
thtanner's Avatar
Sure am.
1992 Trans Am
May 10, 2023 07:19 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
