Tpi tunning issue
Old Aug 9, 2015 | 06:09 PM
squiggy2's Avatar
Car: 89 GTA Trans Am
Engine: L98/383 stroker
Axle/Gears: 323
Tpi tunning issue
Hey guys, have a few questions. I am working on a truck for a friend of mine, the truck has a TPI motor in it with a painless harness. I am assuming its a 90-92 tpi setup, no MAS, has MAP sensor. It stumbles hard after idle and runs rich, bellows black smoke. It throws a code 36, and 44. I have replaced damn near every sensor i could think off and just put a new MAP senson on it. After that it ran good for 10 minutes, took it for a drive and almost couldn't get it back in the driveway it runs so bad, cannot keep it running unless you throttle it hard. Any sugggestions?
Old Aug 9, 2015 | 07:44 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Tpi tunning issue
Strat by troubleshooting not replacing parts. We have no idea what's been done to this motor if anything but it helps to use a guideline. Hopefully the harness is pinned correctly.http://www.chevythunder.com/est_code_42.htm
http://chevythunder.com/o2_sensor_code_44.htm
Old Aug 9, 2015 | 08:29 PM
squiggy2's Avatar
Axle/Gears: 323
I have been troubleshooting. But when all else fails, remove and replace. I would hope the harness is correct, coming from Painless but a possibility it could be miss pinned. I will check that. I did find a dead spot on the TPS sensor today, when i bought the new one from Napa, it came adjustable, slotted screw holes. How do you set that? Never seen that before.
Old Aug 9, 2015 | 08:56 PM
Speed density ecm doesn't care what the tps is set at. As long as the blades are shut it'll be accurate. It takes the baseline voltage and figures off that.
Old Aug 9, 2015 | 09:30 PM
squiggy2's Avatar
Axle/Gears: 323
copy that, thanx
Wade787b
Sep 29, 2015 01:15 PM
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
