hello just signed up and need some advice, 91 350 tpi to 383 tip twin turbo set up
I got a 92 camaro, basically I want a daily driver, with 600 whp. I have a 91 350 tip I want to make Into a 383 stroker, with forged rotating assembly from scat engines and boost it. My question is, what heads should I use, turbos, and keep it tip or change it to carb. Need help plz and thank u.
Engine: 4++,350 & 305 CIs
Re: hello just signed up and need some advice, 91 350 tpi to 383 tip twin turbo set u
You will be getting a whole lot of advice on this, in the mean time, do some more research to see what this will cost in terms of money, time and......
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Only 600? Single turbo tc76-78 or equal. Gt45 mayyy get you there. Vsracing 7875 great choice as well for 420$.
Twins do some sort of t3/t4 hybrid 55-58mm compressors. Think these are often labeled as super 60's or stage 3 50 trims. Whatever lingo, you need around a 55-58 mm comp wheel and similar exhaust side.
Heads nothing special. Low compression piston and a set of summit brand vortecs could do it for real cheap. Aluminum head stuff also can work depending on budget. You dont need a whole lot of special head for 600whp
NinjaNife
Aug 23, 2015 11:49 AM
Sanjay
Aug 12, 2015 03:41 PM
