Dropping gas tank
Old Oct 17, 2015 | 06:37 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Dropping gas tank
I am removing my gas tank from my 1987 5.7 IROC. It is not running and I need to remove the gas from the tank. Anybody have any idea how I can do this. Thanks
Old Oct 17, 2015 | 09:46 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Dropping gas tank
i used compressed air . i first removed the fuel filter then made a "fitting " and blew 20 LBS air through the filler neck. worked like a charm . now you dont have to remove the tank to drain it. but if you have pump problems .. then you do
Old Oct 18, 2015 | 03:11 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Car doesn't run, but if pump runs use it to drain tank. Just undo fitting at filter and jump relay to pump out tank.
Old Oct 18, 2015 | 10:38 AM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
eseibel67 and rusty vango,
Thanks for the information. I will try this. Removing the tank to replace the fuel pump. Anything else I need to look out for while I am doing this job?
Old Oct 18, 2015 | 12:32 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Yes, remove the bolt that holds the brass "T" fitting down for the rear steel brake line that's on top of the rear end. You will have to get the complete rear end WAY DOWN in order to remove the tank.
Old Oct 18, 2015 | 02:46 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
eseibel67,
Thanks for all your help. I manage to get the tank out and on to replacing the fuel pump.
tbroherd
Nov 4, 2015 08:45 PM
TripleTransAm
Oct 26, 2015 01:42 PM
IROCU2
Mid-Atlantic Region
Oct 18, 2015 02:44 PM
GMP318
Carburetors
Oct 14, 2015 08:14 PM
91 zeee
Oct 13, 2015 06:51 PM
