Simple HSR question I need an answer
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
the Weiand stealth ram a lot of money for me I wanna make sure I get the right one I have a 91 with TPI Iron heads. will the regular intake work (7540) or do I need the vortec one (7542)? I just can't find a straight answer, please and thank you
Transmission: T-5, TH350, T-5
Re: Simple HSR question I need an answer
Ummm ok, do you have vortec heads? Easy way to tell is if you have 8 bolts (vortec) holding down the intake manifold or 12 bolts (regular sbc).
okay cool so how do I test the fuel pressure on this set up I mean the HSR fuel rail has no schrader valve to attach to it has an adjustable pressure regulator but I dunno were to test
HSR intake #7540
Holley fuel rail system #534-193
Holley 58mm throttle body
If you have '87 or newer iron heads you'll most likely need the Holley supercharger adapter kit #90748. This is because the intake is design for the '87 and earlier heads.
The fuel rails that I purchased has a schrader valve on the front.
Also, the HSR will did not exactly fit under the hood. It rubs against the dimple in the hood where the insulation clip attatches. This occurs at the plate on the throttle body.
Other than that I'm happy with the install.
LMK if you have any questions.
I have the same fuel rail and I don;t have a schrader valve
ohh wait I got fuel rail 534-186
I have the one with the adjustable FBR that is why I am tring so hard to find a way to test the fuel pressure but it doesn't have the spot for the schrader valve
so apparently mine doesn't have one so I am putting in a
670340 "fuel pressure take off"
my local Napa will have it in the morning
now I am having trouble finding a check valve for it anyone got a part number by any chance
SUPER CHEVY66
16
Dec 14, 2015 02:55 PM
mrestrictrplate
Nov 4, 2015 08:23 AM
