Code 15 Help!!
Old Nov 20, 2015 | 04:19 PM
Logan Bryant's Avatar
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Code 15 Help!!
i was driving my car and all of the sudden it had just lost power. I put the throttle down to the floor and the tach stopped at 3500 and it wouldn't shift either. Once I got home I checked the codes and I got code 15. I have had similar experiences, one was a O2 sensor, and I replaced it and it drove fine.
Just started it up and the idle went to 2300 and them dropped back down to 700. It also started to backfire. When I revved it up, it would take a second to rev, the it would go.
Old Nov 21, 2015 | 03:54 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Code 15 Help!!
Since you have a code 15 wouldn't you troubleshoot that code? Coolant sensor issue. http://www.chevythunder.com/cts_diagnostic_pg2.htm
Old Dec 16, 2015 | 11:32 AM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Re: Code 15 Help!!
I've got a code 15 right now (86 IROC 305 TPI) and it runs like a scalded dog anway. No issues spinning tires, getting pushed back in the seat, hauling *** down the highway, etc.
I'm about to go out and check the voltage on the yellow wire now as a second step (replaced the sensor and plug yesterday). Getting to the computer to check the wire from the sensor/plug back to the computer will be a little tougher (for me).
I was looking for the info on the computers (in case I have to buy another one) when I ran across this thread.
redbird_400
May 19, 2002 02:46 PM
turtle
Aug 23, 2001 10:13 AM
Morty
Apr 23, 2001 09:08 AM
jobryan26
Apr 9, 2001 02:30 AM
