Interchanged Fuel Injectors
Old Dec 23, 2001 | 01:35 AM
Ebby's Avatar
Car: Red 05 Viper SRT 10 & Yellow 03 Z06
Engine: 87 Camaro - 355 TPI Custom
Transmission: 5 Speed BW World Class
Axle/Gears: 3.73:1
I just bought Bosch 24# Injectors made for Ford Motorsport. They're supposed to be interchangeable with the Chevy TPI injectors. First thing I noticed is that they are really skinny by comparison, the second was that they don't have provisions for retainer clips and the third is that their made of plastic. Will these things really work with a high pressure TPI system, or will they leak like a sieve!! What am I supposed to do, just shove them into my fuel rail without a retainer clip and hope they stay in? (DAMN FORDS!)
Old Dec 23, 2001 | 10:22 AM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
I've been running mine that way for 1 1/2 years and haven't had a problem yet.
Sparks a flyin'
Old Dec 23, 2001 | 02:25 PM
Guest
Guest
Posts: n/a
Really skinny? Are you sure those are the right injectors? They should be the same diameter... sounds like you may have a set of 4.6 injectors in your hands, and I dont think those will work.
Old Dec 23, 2001 | 06:09 PM
Ebby's Avatar
Axle/Gears: 3.73:1
Skinny Boschs Injectors
Yeah, they're kinda skinny, they look just like the new Corvette LS1 injectors. Any thoughts? Their part # is 280-155-710.
Old Dec 23, 2001 | 06:14 PM
On the box mine came in: Part # M-9593-A302 24# Injector Kit
Doesn't list individual part #.
Got to agree with MadMax.
Sparks a flyin'
Old Dec 23, 2001 | 06:22 PM
Ebby's Avatar
Axle/Gears: 3.73:1
Skinny Bochs
Well, the part # I'm getting is off of the injectors themselves. Their listed to be for the Ford 5.4, 5.0 AND 4.6. Their supposed to be a brand new design for 2002. I don't know. They fit into my fuel rail and the intake manifold opening.
I got them from the guy who runs "www.fiveomotorsport.com". He claims he's been selling them to TPI guys with no problems. I looked all over the net trying to find a web page that lists BOSCH injector part numbers and I couldn't find this one, only older ones. So if anyone knows about a site that lists BOSCH part numbers I'd appreciate it. Again, they're yellow/orange and they look just like the new LS1 injectors; kinda skinny, but the same length as the TPI injectors.
Old Dec 23, 2001 | 06:29 PM
OK, I'd try em and see if they work (I think they probably will). I just looked at one of mine : Part #280-150-947 Black body with blue top.
Sparks a flyin'
Old Dec 23, 2001 | 07:01 PM
Ebby's Avatar
Axle/Gears: 3.73:1
I just measured them since my last post and they are approximately .25" longer than the stock injectors. That is, the stock injectors are 2 inches and 3/4 or 7 cm and these are like almost 3 inches; approx 7.5 cm. I don't know if this even matters.
Old Dec 23, 2001 | 11:05 PM
FstBrd6point3's Avatar
it prolly will, since when you torque down the bolts for the fuel rails you are going to crush the seals between the manifold and the injector, U can just make sure not to torque it too tight but U had to do it twice on my tlaon cuz I ****ed up the first time, so I suggest doing it right the first time
Old Dec 24, 2001 | 09:27 PM
Ebby's Avatar
Axle/Gears: 3.73:1
In case anyone cares, I think these damned injectors will work. Although they are .25" longer than stock, they go deeper into the manifold. And from what I understand, the LS1 injectors will work with the L98 TPI. (I HOPE!)
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
