89 Camaro
Old Apr 1, 2016 | 12:36 AM
Rule69's Avatar
Car: 1986 Camaro
Engine: 305 for now
89 Camaro
Just bought a 89 Camaro a few days ago. The vin says I have an L03 but I have a TPI. How can I find out what motor is really in it and where to look?
Main problem is the maf is unplugged and it will crank over and run. With the maf plugged in she will crank and turn about 5 time but stumble and die.
Thanks for your help.
Old Apr 1, 2016 | 11:13 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: 89 Camaro
Thought they went to speed/density in 89??
What the vin says, is what the car came with stock. You can check block casting numbers, if you can see them.... should be on the bellhousing part of the block, drivers side.
Old Apr 2, 2016 | 05:16 AM
Rule69's Avatar
Car: 1986 Camaro
Engine: 305 for now
Re: 89 Camaro
I think it was 90 hey went to speed density. I'll post up some photos if the engine. Think I may get a wiring harness to make sure everything is hooked up or just start making my own
1987GTA5.7LITER
Sep 26, 2017 11:51 PM
87-bird
Mar 4, 2016 05:04 PM
FireballXL5
Feb 26, 2016 04:29 PM
85Maroon
Feb 21, 2016 06:44 PM
Zylinder
Feb 12, 2016 12:00 PM
