Help With this tpi guzzling gas, High blm
Old May 25, 2016 | 06:06 PM
nikom1's Avatar
Car: 1987 Trans Am
Engine: 5.7L 350
Transmission: Automatic
This is the scanner connected while driving any thoughts?
Old May 27, 2016 | 11:51 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Help With this tpi guzzling gas, High blm
I'm not the best at decifering datalogs but have you changed injectors? Maybe to a different brand? I'm sorta stabbing in the dark but injector PW v battery voltage values maybe different enough to cause an issue, in which case you'll need to change it in the PROM.
Old May 27, 2016 | 03:32 PM
nikom1's Avatar
Car: 1987 Trans Am
Engine: 5.7L 350
Understandable, but injectors were replaced and did not change anything from the Original injectors on the motor.
Old Jun 7, 2016 | 12:12 PM
nikom1's Avatar
Car: 1987 Trans Am
Engine: 5.7L 350
Thoughts???
1Aauto
Sponsored Vendors
Jul 27, 2016 01:25 PM
Calvin.w44
May 26, 2016 12:51 PM
Zylinder
May 19, 2016 02:09 PM
SethMorris
Apr 24, 2016 07:23 AM
Polo Z03
Mar 27, 2016 08:17 PM
