L98 Cylinder heads
Old Jun 7, 2016 | 12:13 PM
JD Z28's Avatar
Car: 89 Iroc Camaro
Engine: 5.7 l98
Axle/Gears: 3.70
L98 Cylinder heads
Hey guys how's it going?
Blew a head gasket on my 89 5.7. Come to find out, 4 valve guides are cracked. Thinking about switching to aftermarket heads. The car has a small cam in it (unknown specs) AS&M runners, ported intake plenum and base, and short tube headers.
Found a set of SBC "Power Pack heads.
60cc chambers
1.72 intake valves
And 1.5 exhaust valves
Casting # 3795896
Would these work? On and L98
Old Jun 7, 2016 | 11:31 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: L98 Cylinder heads
Yes and no. Yes, with some modification to the manifold center bolt holes. No, they are old 60's lo-po heads that unless really reworked will kill any performance and may not have the front accessory holes for your alternator and a/c brackets. Stay away from them. Why don't you have the guides replaced in your heads?
Old Jun 8, 2016 | 12:42 PM
JD Z28's Avatar
Car: 89 Iroc Camaro
Engine: 5.7 l98
Axle/Gears: 3.70
That's what I ended up doing. Having the guides replaced. Thanks for the info though
Bowtieman1970
Aug 17, 2016 02:50 AM
Flybird8488
Jun 26, 2016 04:53 PM
igotta355z28
LSX and LTX Parts
Apr 11, 2016 08:21 AM
dwrestle
Apr 5, 2016 12:12 PM
JD Z28
Mar 28, 2016 09:46 PM
