Diagnostic Help
Old Jun 22, 2016 | 11:39 AM
mbailey713's Avatar
Car: 89 firebird formula
Engine: 305 tpi
Transmission: 5 speed
Diagnostic Help
I have an 89 FB 5.0 TPI. I started noticing a hesitation and jerking when at slight throttle to maintain speed a while back. Accelerating was fine, idle so-so. Now it's idling terribly at times, the jerk in the car is more and also does it at 50 mph. I got after it the other night and it started breaking down and losing power around 3000 RPM. I'm thinking fuel pump or maybe CATs. I've contemplating changing plugs and wires but they're not that old and I'm not sure they're the issue. Looking for diagnostic help. Thanks
Old Jun 24, 2016 | 02:20 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: Diagnostic Help
Sounds like the infamous Multec fuel injectors are failing. ohm them out and I'll bet you find a few shorted.
Old Jun 24, 2016 | 04:22 PM
mbailey713's Avatar
Engine: 305 tpi
Re: Diagnostic Help
Thanks for the tip. I ohmed the injectors and got readings from 4.7 to 15.7. What range should they fall in? Looks like you're right about the injectors.
Old Jun 24, 2016 | 04:24 PM
battman's Avatar
Re: Diagnostic Help
Around 15 ohms. That 4.7 is your problem..
Old Jun 24, 2016 | 04:27 PM
mbailey713's Avatar
Engine: 305 tpi
Re: Diagnostic Help
A new set of injectors it is. I changed plugs and fuel filter today because they're cheap and I was hopeful. But no improvement. Thanks for the help.
mthibode
Apr 12, 2016 07:04 AM
jimw67
Apr 2, 2016 01:06 AM
Kakdiesel1
Apr 1, 2016 04:33 PM
Abubaca
Mar 29, 2016 08:16 AM
thebossmanscot
Mar 27, 2016 11:11 AM
