will a LT1 throttle body work with TPI?
Old Dec 26, 2001 | 02:25 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I am asking this because I like the new throttle body from Holley with the NOS fitting made into it and I want that for my TPI. I have only seen it for the LT1 so would it work?
Old Dec 26, 2001 | 02:40 PM
wataru's Avatar
I think they use the same 48mm tb. Someone wanna back me up on that?
Later Barrett
Old Dec 26, 2001 | 03:58 PM
Kevin G's Avatar
The linkage is different, and also the LT1s dont have a vacuum port for the EGR.
It can be modified to work in a TPI with some work. I had a 58mm LT1 Tb on my L-98 a few years ago..
Old Dec 26, 2001 | 04:33 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Yes, it'll work. Not a simple bolt on though even though the bolt pattern is exactly the same.
the linkage is differant and will require a LT1 throttle cable too. If you have an automatic you'll need a throttle body from a 1993 to get the TV cable hookup.
Old Dec 26, 2001 | 09:02 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Another thing you need to keep in mind.... that throttle body will give you a dry nitrous shot meaning you take a very high risk of leaning the enging out if you don't compensate properly. With a wet nitrous system that requires a plate between the TB and plenum, there's a hookup on the plate for the Nitrous AND a fuel line so you have the proper mixture of fuel and Nitrous and don't have to worry so much about the engine leaning out during the shot.
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
