O.K Guru's- whats the best injection setup
Old Dec 26, 2001 | 05:01 PM
Idagon's Avatar
I have a 350 vortec headed engine that makes 397hp with a Performer RPM and holley 750
i want to convert it to TPI.
what are my choices?
is there ways to run a stock tpi manifold and aftermarket controller... ?
Old Dec 26, 2001 | 05:25 PM
kevinc's Avatar
Car: 1982 Z28
I'm not a guru but I'll chime in anyway....
With the Vortec bolt pattern you have three off-the-shelf options:
1.) Scoggin-****ey's TPI base, which will allow you to run a stock-looking TPI setup. This is the only TPI-compatible base that fits the Vortec pattern at this time.
**NOTE the way the new UBB auto-censoring software asterisked-out D1CK in Scoggin's name above...too funny!!!
2.) GM's "RamJet" intake. This uses an LS1 throttle body, is one piece rather than separate plenum/runners/base, and can be bought with a standalone ECM and harness. It could probably be made to work with a TPI ECM ('165, '730) without too much hacking.
3.) TPIS "Miniram III" intake. This uses a TPI throttle body, is also one piece, and is designed to work with stock TPI wiring harness.
You can run a stock ECM or aftermarket controller with TPI, Accel DFI and Haltech are common options. A new player formerly known as Speed-Pro is also out there...check out www.fuelairspark.com for info.
With aftermarket ECMs you gain realtime programmability but lose variable breadth compared to GM units in my experience. They also cost a bunch more.
Ranbo108
Sep 9, 2015 12:20 PM
jonnythewrench
May 27, 2012 11:44 PM
isitluck11
Jun 3, 2011 01:41 AM
burnout88
Nov 2, 2004 07:48 PM
