ADS Supership?
Old Dec 26, 2001 | 08:46 PM
IROCKER's Avatar
ADS Supership?
Does anyone have this one? I think it's the street version. I won't be able to install it till the spring so I'm wondering what kinda results I should expect.
Old Dec 27, 2001 | 08:20 AM
Desert86Roc's Avatar
I do not recommend those chips. You will get more out of tweaking your existing setup than using an off the shelf chip like that. Check out the DIY Prom board. There are a lot of better options out there.
Old Dec 27, 2001 | 08:52 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I had one on my car (before I got into eprom burning). It actually hurt my car's performance and when I looked inside the eprom I saw why. First, the Superchip did VERY LITTLE (a little extra fuel, a little extra spark and locked the TCC a few MPHs higher).
What made it bad, was the changes to the both the fuel and spark tables. They screwed up some of the settings and if you "graphed" the tables, it looked liked "waves on an ocean". After I tuned my eprom, it now has a Fuel Table that has a direct relationship to the VE% and makes more sense. Also, my 20-70 mph times (how I compare various BINs for performance) decreased by over .3 seconds (with my tuned eprom).
YES, you can get some noticeable performance increases even on a basically stock engine with proper tuning of the eprom. In fact, the BEST time to start burning your own eprom is when your engine is still basically stock. I currently have over 2,000 differences between my stock eprom and my currently optimized eprom My ADS only had about 50 differences and they weren't good changes.
Old Dec 27, 2001 | 05:01 PM
IROCKER's Avatar
Thanks guys.
Ed1LE
Sep 30, 2018 09:14 AM
86IROC112
Nov 7, 2015 06:50 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
