Scan tools for TPI
Old Dec 27, 2001 | 09:30 AM
91TA's Avatar
Scan tools for TPI
What are some good scan tools that can be used for solving problems / doing tune ups on tpi engines. What is everyone using.
Old Dec 27, 2001 | 10:01 AM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I have DataMaster, its frame capture speed is plenty fast, and has more information than I know what to do with. Records, plays back, graphs, etc.... You can get a free download version that allows you to record up to I think 12 or so times before you have to purchase it, that is if you have the cable hooks ups that connect the ALDL plug to your laptop Serial port.
Here's a link to AKM thats sells several scan tools, DM is the first on the list, and its fairly cheap compared to others as far as price.
http://www.akmcables.com/dss.htm
Tell Andrew I sent you, I'm the guy with the TPI Truck.
Old Dec 27, 2001 | 10:04 AM
91TA's Avatar
Thanks, I'll check on the DM after work.
Old Dec 27, 2001 | 11:17 AM
BlazinOR's Avatar
For a handheld I use the new Auto Xray - replaces the 240 model. Cost about $150 but worth it.
Old Dec 27, 2001 | 02:07 PM
2QUIK6's Avatar
I forgot to mention, DataMaster requires the use of a laptop computer, its not a self contained device as the one mentioned above. Not sure which you are looking for.
Old Dec 27, 2001 | 02:24 PM
91TA's Avatar
Looking for a handheld unit. Where can I get the auto x-ray, or at least some info on it.
Old Dec 27, 2001 | 02:27 PM
91TA's Avatar
Found the website. Thanks anyway
Old Dec 27, 2001 | 05:19 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Scan tools for TPI
i have 2 OTC scanners. these are the ones that you can do diagnostics, pull codes, and read datastreams. they now have software that you can use it with your PC also. the one i am trying to get rid of is the OTC 4000e. it works from '79-'97 all domestic. it will do engine, abs, and airbag. my add is at www.fl-thirdgen.org in the parts for sale section. asking $700.00. it is a handheld unit.
Old Dec 27, 2001 | 06:15 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I have a refurbed AutoXray I got for $89. Handheld unit and does a good job for the price. Here's the link.
http://www.autocheckup.com/refurb.htm
Dkelz313
Apr 7, 2016 10:38 PM
gta90
Sep 15, 2015 04:00 PM
383backinblack
Aug 15, 2015 06:36 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
Sanjay
Aug 12, 2015 03:41 PM
