91 transam cold starting
Old Jul 30, 2016 | 04:31 PM
jvaughan's Avatar
91 transam 5.0 tpi doesn't want to start without pressing the gas pedal. When it does start, it runs rough for a couple of minutes and finally runs good after a little "warming up ".
Old Aug 1, 2016 | 03:32 PM
keykey's Avatar
Car: 1988 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH700R4
Axle/Gears: 3.27 9-bolt w/ Torsen LSD
Re: 91 transam cold starting
Check the temp sensor. My -88 was acting like that when the ECU was broken and the 5V-circuit that feeds the temp sensor only put out about 2 Volts.
When I finally got a ALDL-cable and plugged it in, I could see in Live Data that the temp sensor reported +30 degrees C to the ECU when the engine was actually +6 degrees C.
Old Aug 1, 2016 | 08:15 PM
jvaughan's Avatar
Thanks keykey will put a new one in tomorrow
dagab
Jun 4, 2017 03:18 PM
mjb198421
Apr 4, 2016 03:46 AM
neilcase
Mar 21, 2016 10:08 PM
TRAXION
Aftermarket Product Review
87
Nov 22, 2008 10:33 PM
theformula
Dec 13, 2000 01:04 AM
