350 TPI Midrange Hesitation
Old Aug 16, 2016 | 09:24 AM
scoutcamper's Avatar
Hey Everyone,
Finally got my TPI in my 1965 C10, and finished everything up so I can take it for a drive. Results of the test drive: 4.11 rear end helps make this thing a tire roasting machine
HOWEVER: 2 issues cropped up.
Issue 1, The alternator is not charging. I will be debugging this tonight, suspect ignition sense wire is not working for some reason...
Issue 2: The motor has a pretty bad midrange hesitation. It will fly up to somewhere around 3500rpm(guessing at that, no tach yet), then hesitate for a good second, then fly up till it shifts. Any guesses as to the cause? I am running S_AUJP_V4 in my computer, timing is set to 6degrees BTDC. Trans is a 700R4.
Thanks in advance!!
Old Aug 21, 2016 | 02:40 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Re: 350 TPI Midrange Hesitation
Impossible to tell without logs showing data.
i88aGT
Apr 6, 2016 06:53 PM
iiAmDomo
Aftermarket Product Review
Mar 24, 2016 02:27 AM
91banditt2
Mar 23, 2016 12:11 PM
NHL69
Exterior Parts for Sale
17
Mar 17, 2016 09:36 PM
deathpunch016
Mar 15, 2016 06:11 PM
