Adding guide plates to use non self aligning rockers on a 91 TPI???
Old Sep 7, 2016 | 09:17 AM
raptere's Avatar
Car: 1991 Camaro Z-28 (Durango R/T)
Engine: 383 L98 W/ HSR
Transmission: 700R4 Tuned Shift 2600 Stall
Axle/Gears: 3.73 10Bolt Posi W/ Al Cover, Disks
Hey all, first post in probably 10 years on here, LOL!
So back when I was in high school I bought some really nice roller rockers, comp cams pro magnum full roller chromo 1.6 ratio rockers. I got push rods at the same time. I had grand plans for the car, such as new heads so I specifically bought the non self aligning rockers for them, but the new heads never happened. Question is, can I just add guide plates to the factory L98 heads to use the non self aligning rockers, or would I be best off trying to sell the rockers here or on ebay and just buy the correct self aligning ones for my heads? If I were to get the guide plates would I also have to get new studs? Would there be any downsides to doing this? Benefits? This is no longer my daily driver, I basically drive it about 50 miles once or twice a week in the summer to and from work and around town. I don't need crazy power but 10 or 15 hp would be way nicer to have than a box of parts taking up space in my garage! Hopefully my sig still has all my engine info, if you need anything else to accurately answer, just ask.
Thanks!
Eli
Old Sep 7, 2016 | 10:41 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: Adding guide plates to use non self aligning rockers on a 91 TPI???
I'd sell them and use that money for something else....like better flowing heads. Roller rockers, even going from 1.5 to 1.6 are probably not going to translate into anything near 10-15 hp to your rear wheels.
Old Sep 7, 2016 | 02:37 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
NSA rockers are too much "trouble" for a TPI. You'll have to invest in guide plates and ideally hardened pushrods. NSA are better for higher RPM which TPI doesn't see.
I say sell them and get some SA rockers, and there is more they do for you than just 10-15whp at peak. They add power across the entire powerband and increase mpg.
Old Sep 8, 2016 | 08:42 AM
topless87's Avatar
Car: 1987 IROC-Z Convertable
Transmission: 5 Speed BW T-5
Axle/Gears: 3.08 Posi
For guide plates you have to mill the old rocker towers down, have them tapped for screw in studs in order to hold the guide plates on. Also, with 1.6 ratio, if you don't have your pushrod geometry correct you end up with "Z" shaped pushrods at some point, ask me how I know...I agree with the others, sell them and put the money to a better performance use unless you are willing to tear the heads off for all of the work needed. MTC
Old Sep 8, 2016 | 10:48 AM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Look up Professional products They sell a set made by Jomar.They are they are thin and very adaptable.They are not like any other guide plates out there.You will have to use hardened push rods with them.
Old Sep 8, 2016 | 03:06 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
First, take off a valve cover and look at the push rod holes.
Some heads came with round holes, some came with oval holes.
If you have oval holes you can use non-SA rockers.
Old Sep 10, 2016 | 03:35 PM
raptere's Avatar
So getting new heads to accomodate the rockerss would not be an ideal solution any more financially. Even though that was my intention back when I got them.
So am I understanding it right that the factory heads have pressed in studs instead of threaded ones that are generally required for guide plates? I found those jomar guide plates. Are you saying I could use those with my existing heads and studs? I do have hardened rods I ordered at the same time as the rockers, sitting in the same box as the rockers.
I can pull a valve cover and look at my heads. Are you saying heads intended for self aligning rockers had the round holes, or that even though there are no guide plates I could still use the non self alligning rockers with a head with oval holes, even it it was originally installed with self aligning rockers?
Old Apr 12, 2017 | 02:40 PM
raptere's Avatar
Well, some time has gone by and I've decided to just sell off these rockers and buy some replacement S/A ones.
If anyone is interested there posted here on TGO: https://www.thirdgen.org/forums/engi...-cams-pro.html
slow305
Nov 12, 2017 03:25 PM
MantyZ28
Exterior Parts for Sale
22
Apr 10, 2017 07:07 PM
thewizard
Mar 22, 2017 02:54 PM
MantyZ28
Nov 4, 2016 05:13 PM
Finally Got one
Aug 8, 2016 01:59 PM
