what octane is appropriate for the TPI?
Old Jan 13, 2017 | 06:50 PM
truckguy's Avatar
Was really low on gas ..engine was dying on my way home. Used some of my go kart gas, which is 87 octane so I can get to the station.
I barely poured like a dollars worth, stopped bc I realized it was 87.
I want this engine to last around 2-4 years, but only driving once a week and maybe some car meets. As for my driving style, like to rev high sometimes , but not excessively.
Is 87 fine for this engine use or should I go with higher?
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: what octane is appropriate for the TPI?
91
TPI ECMs are tuned for it
Old Jan 14, 2017 | 04:39 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
89 octane is what it requires but you can run 87 safety as long as your timing is stock°6
Old Jan 17, 2017 | 08:12 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The 1987 owner's manual states that TPI engines should use premium unleaded fuel with an octane rating of at least 91.
87 octane can be used but there will be reduced acceleration performance.
Old Jan 18, 2017 | 09:16 AM
92GTA's Avatar
I never got any pinging or knock on my LB9 with 87 according to my data logs. I actually got much better mileage using 87 compared to 91.
If you aren't daily driving it and only using it once a week, by all means use 91.
Old Jan 18, 2017 | 09:23 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Mine LOVES Sunoco 93 Ultra
Old Jan 18, 2017 | 09:48 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Here in Europe, I use 102 octane (RON) in my '88 TPI.... available at some stations as Competition 102.
Contains no ethanol, and that's the most important aspect in my case, as I hardly drive my car these days anymore...
Old Jan 18, 2017 | 10:27 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Best I can do on the non ethanol is 91. I usually run this. Less pressure buildup in tank.
I can get 110 racing fuel for 7 bucks a gallon, no need though.
Old Jan 19, 2017 | 08:16 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
That's all I use on both of my toys.
Old Feb 4, 2017 | 08:49 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
wish I had Sunoco near me!
Old Feb 5, 2017 | 11:11 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
When I used to dd mine, I would run 87 until Friday b4 work, then it was 93 for the track and weekend activities. Don't think it helped much if any with a stock motor.
Old Feb 6, 2017 | 05:37 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
I run 91 at all times and get knock. My car would greatly benefit from 93. The oem timing logic is a bit odd.
Old Feb 7, 2017 | 09:01 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I have ran 87-93 and don't see any difference with stock timing and ECM.
Old Feb 7, 2017 | 11:38 AM
thtanner's Avatar
Are you datalogging?
If so, you will see a difference. I have done that and knock count was higher with 87.
Old Feb 7, 2017 | 12:14 PM
Engine: LB9
Axle/Gears: 3.08
I watch KR 100% of the time with the dash light flashing at me, so I definitely know when I have it.
BUT every car and environment is totally different. Not too many places more taxing than AZ on a car. If I had this car in WA it would be knock free on 92 (maybe even on 89octane 90% of the time.)
Old Feb 7, 2017 | 12:20 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I was on my old car, but only ran 93 in it, of course. The current car is an 85 Iroc that I haven't logged and is bone stock. No audible spark knock, and 6 * timing.
Old Feb 7, 2017 | 12:29 PM
Engine: LB9
Axle/Gears: 3.08
Listening for knock is not accurate. And using two different cars introduces a variable rendering it useless for info regarding octane effect.
Old Feb 14, 2017 | 07:17 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I was only giving examples of times when, of course, running a higher octane is needed. I had a MSD knock light on the dash in it..... It would only lightly flash before audible pinging started anyway.
BUT, since you obviously are looking an argument. Why don't you log 87 and 93 in the SAME stock car with stock base timing and see what happens?
Old Feb 14, 2017 | 09:12 AM
Engine: LB9
Axle/Gears: 3.08
I already have.
Old Feb 15, 2017 | 10:11 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
OK. Can you post them up for us?
Old Feb 15, 2017 | 01:45 PM
Engine: LB9
Axle/Gears: 3.08
Nope. You'll have to take my word on it.
Old Feb 27, 2017 | 12:09 PM
brianlibby791's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 350 TPI (Deleted Cats)
Axle/Gears: Original 3.27
I never really experimented with different octanes (Its only had one fill up in the past 7 years) but i run sunoco 93 and runs like a top. On my dads daily he runs 87, but when he treats it with 93 it runs a little better, as well as an increase in gas mileage. By around 3 mpg's. But all thats ever been in my L98 in sunoco 94 octane (when it was still around) and 93
