Homemade Cold Air Intake Questions...
Old Dec 31, 2001 | 06:07 PM
lancer5067's Avatar
Hello Esteemed Third GENers,
I am currently looking into the possiblities of a homemade CAI, I have MAF and am not willing to relocate plus I think the MAF to TB stock hose is pretty cool. So everything forward of the MAF is under review but I do not want an external RAM. My main question is that everyone removes the canister, given, but I am confused after that. Do most folks just stick the filter on the piping and call it good? Where the heck does the cold air come from exactly, the fan? Also what can I use as a transition on both ends of the piping that will look decent? Thanks all!!
Old Dec 31, 2001 | 08:16 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Check the tech articles...or you can go here:
http://87tagta.tripod.com
click on CAI to see my setup.
Old Jan 1, 2002 | 12:32 AM
lancer5067's Avatar
There's a lot of good information there, it seems like the fender opening is pointless but I like my foglights too much for the ram. Has anyone tried to cut a hole into the plate below the stock can for more air flow??
Old Jan 1, 2002 | 10:30 PM
ONEFORMULAOVERALL's Avatar
yes cut the metal added a scoop to direct air straight 2 the filter,
works great
Old Jan 1, 2002 | 11:07 PM
lancer5067's Avatar
Could I please get a pic of how you did it, I'd greatly appreciate it thanks!
Old Jan 2, 2002 | 06:30 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Cold Air
I ran my home made cold air to the driver side on my Camaro. I drilled a large diameter hole through the unused battery tray and mounted the K&N filter under the battery tray. This got it out of the hot engine bay and into the cooler air of the inner fenderwell.
I then fabricated a scoop that bolted to the leading edge of the fenderwell plastic liner. This scooped air into the fendwell.
Old Jan 2, 2002 | 07:13 PM
Ron Mullins's Avatar
Here's what i did.
http://www.geocities.com/91formula/ramair.html
Old Jan 3, 2002 | 06:28 PM
rondubbs's Avatar
i also did Ron Mullin's cold air setup.. its definately the best one because its getting air from outside the engine compartment....
Old Jan 4, 2002 | 06:16 PM
Cool, glad to hear some else like it and is using it.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
