305 TPI
Old May 10, 2017 | 04:33 PM
mrd's Avatar
mrd
Want a title? Post!
305 TPI
I have a 1986 305 TPI. It is hard to start and sometimes it will cutout going
down the road,but will refire. Is there a crank sensor on this engine and if so
can you tell me where it is located. I think its going bad. Thanks
Old May 10, 2017 | 07:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 TPI
Sounds like fuel starvation, injectors or pump. No crank sensor there is a icm and pickup coil in your distributor.
Old May 10, 2017 | 10:33 PM
GeneralDisorder's Avatar
Re: 305 TPI
These are also notorious for cracked ECM circuit boards.... if you don't find anything on the fuel or ignition system side of things.
GD
factory89tpi
Sep 29, 2016 05:24 PM
89trans_am
Sep 25, 2016 11:09 PM
keithl1967
Sep 24, 2016 01:20 PM
dr.watkins9
Sep 22, 2016 03:33 PM
MASON1259
Sep 13, 2016 11:30 PM
