What is the G92 engine?
Old Jan 1, 2002 | 04:16 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
My Camaro book says the 91 Z28 came with three possible 305ci V8, the LO3 (170Hp, which is the TBI engine) the LB9 (210HP) or G92 (230HP). I know the LB9 is the TPI motor, which I have. The Chilton repair manual I bought says that the VIN code number for the engine, which is F, means it is a 5.0 TPI. But the Chilton book doesn't mention anythinga about the G92 engine. They guy I bought if from said it was a 305tpi "HO" motor but he really knew less than I do about it. What is the G92 engine?
thanks
Old Jan 1, 2002 | 05:26 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I thought G92 was the RPO# for a 3.42 posi rear?
Old Jan 1, 2002 | 05:37 PM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
Itr is a performance package, that, on trhe 305TPI, boosts output to 230(pre 91) or 240(91-92) hp due to dual catalytic exhaust, also has 3.42 posi, and4wheel discs. To get a 1LE you had to order G92 and delete AC...
Old Jan 1, 2002 | 07:47 PM
Car: '91 Formula
ok, so the G92 is not really a different engine, its just a performance package, specifically what you get when you order the 1Le package right? I know I dont have the 1LE package so I must have the normal 305tpi with 210 HP. This is what I thought.
Old Jan 1, 2002 | 09:15 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The LB9 G92 Package was available on 5 speeds and came with a different cam profile, AFAIK.
I could be wrong, but I am only human.
Old Jan 1, 2002 | 09:56 PM
rezinn's Avatar
Seems like G92 meant different things different years. On my 87 iroc G92 stood for the 3.23 limited slip differential. I believe G92 is just a performance differential.
Old Jan 1, 2002 | 10:18 PM
92RSB4C's Avatar
Here's what thirdgen.org's RPO decoder says:
Your query has found 1 match!
Here are your results:
G92 : AXLE REAR RATIO, PERFORMANCE
Old Jan 1, 2002 | 11:06 PM
Zepher's Avatar
Ya, I looked at the tech data on the 91 LB9 with the G92, different gears and more HP.
Old Jan 2, 2002 | 12:31 AM
HM Murdock's Avatar
What I meant was...G92 is INCLUDED with 1LE, but having G92 does not mean you have a 1LE...If you ordered teh G92 Performance Package, then deleted teh Air Conditioning, the 1LE package is automatically selected...
On my window sticker, it lists this:
Performance Enhancement Group 444.00
Consists of:
Power Brakes, Disc frt & RR
Engine Oil Cooler
Dual Converter Exhaust
Performance Axle Ratio(3.42 on my 1LE)
Old Jan 2, 2002 | 09:14 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
g92 was only a performance rear end combo, what the combo is, i dont know, but it usualy went with the g80 rpo for posi. i think that there were only 2 305's offered. the LB9 which was the TPI
or the LO3 which was TBI, and then there was L98 for the 350 tpi.
I know in 88 or 89 they went to a better cam for the LB9and offered the n10 option, dual cats. along with the 1le, g92, and in 91-92 the B4C police option. also if you got the 91-92 lb9 with a 5 speed, those cars (stock for stock) could almost runs with the 350's. Of coarse, dont quote me on this
Old Jan 2, 2002 | 09:30 AM
Zepher's Avatar
Personally, I think the 91-92 LB9's with 5 speed and the G92 package would be quicker than the 91-92 L98's with the G92, only because the manual is lighter and there is less drivetrain loss.
Are there any stock 1/4 mile times and 0-60 times for these years and models?
I'd really like to know.
Old Jan 2, 2002 | 11:39 AM
HM Murdock's Avatar
You can quote me, though...
Old Jan 2, 2002 | 10:10 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
G92 meant the better rear end ratio for both 5-speed TPI cars and automatic TPI cars. On 89-92 models, it also meant the upgraded exhaust with dual catalytic converters. Non G92 models were 205 HP for the 89-92 305 TPI and 230 HP for the 305 5-speed, and 245 HP for the 350 TPI automatic. The 25 HP difference between the 305's is attributed to the exhaust, and a little bit of underrating by GM. They have the same cam from 90-92 for sure, the 88-89 years I do not know for sure.
The 305 5-speed G92 and 350 automatic G92 both ran about the same 1/4 mile time, but the 305 was a couple tenths and 1 or 2 MPH slower, on average.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
