Anyone using Fastburn Heads with TPI?
Old Jan 1, 2002 | 10:46 PM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
I want to get these Head and also need to know what intake to get. I want to keep a TPI set up . Thanks for any info.
Old Jan 2, 2002 | 12:00 AM
Earl 87gta's Avatar
you have to Have the SDPC base or you HAve to modify your stock base. Ive done it both ways now and if you have a lot of cam and the fast burns then buy the SDPC base with vortec heads and a mild cam mod yours to work. Just so you know that base is 400 you can check it out at SDPC2000.com
Old Jan 2, 2002 | 10:00 PM
Timbo89GTA's Avatar
Engine: 383 TPI
Axle/Gears: 3:27
Would the Edelbrock High Flow TPI Baseplate be just as good as the Vortec? Its only $334. Will it work with Fastburn heads and L98 block? thanks for any info. Timbo
Old Jan 3, 2002 | 01:20 AM
Earl 87gta's Avatar
Edlbrock make the SDPC vortec base for them. the Standard edlpbrock tpi base will not work with the heads I you set the standred edlbrock tpi base on my engine you will see abought a 1/8 in of the itake ports of the heads past the base. I use to have a few pics of this but my house burnt down so I no longer have them but I do have a engine on a stand out of a 97 GM truck I think I have a stock tpi base still If I do I will take a pic so you can see what Im talking a bought.
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
