Fuel tank baffles
Old Jul 15, 2017 | 04:43 PM
siutech's Avatar
Car: 1990 IROC Z28
Transmission: MD8
Axle/Gears: G80 G92 GU5
Fuel tank baffles
just a few close ups, never could find any...1990 Iroc
Old Jul 15, 2017 | 05:43 PM
Drew's Avatar
Re: Fuel tank baffles
I've posted photos a few times in the past... But seeing how Photobucket decided to Photophucket... These pics are better than mine anyway.
Old Jul 15, 2017 | 07:47 PM
siutech's Avatar
Car: 1990 IROC Z28
Transmission: MD8
I was glad to see everything clean and intact. Just purchased this one in May and had to replace the sending unit (did the fuel pump also). The vehicle has an extremely clean undercarriage.
Old Oct 6, 2017 | 07:44 AM
Fluf97zj's Avatar
Car: 1989 RS Camaro coupe
Engine: 2.8l V6
May I ask, that looks like a new tank. What brand is it? I am guessing the filler neck lined up correctly? I purchased a spectra I believe for my 89 RS and the filler neck is way off.
Thanks in advance.
Old Oct 6, 2017 | 11:11 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Thanks in advance.
It's an original 89ish to 92 GM tank.
You can bend the necks a little to get them into position.
Old Oct 15, 2017 | 07:32 AM
siutech's Avatar
Car: 1990 IROC Z28
Transmission: MD8
Original tank, as far as I can tell. I did add some 2-part epoxy around the filler neck to tank joint, whether that was right or wrong?
Old Oct 16, 2017 | 06:43 AM
TTOP350's Avatar
Its best to just take them to an old radiator shop and have it re-silver soldered.
Old Oct 25, 2017 | 11:25 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Where did you get this tank?
I'm still looking for something
Old Oct 25, 2017 | 12:27 PM
TTOP350's Avatar
Any 90-92 F-body will have this tank.
Old Oct 25, 2017 | 12:31 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
For some reason my 85 z28 has the baffle in it. Baffling lol
Old Oct 28, 2017 | 12:47 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
photophucket I like that
Old Oct 28, 2017 | 01:03 AM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
My '90 had a tank like that (just as clean inside) I pulled it and sold it to someone who had a tank that was all rusted out inside. Put the money towards a 99-02 style tank. It uses a fuel bucket. It works way better than the baffled tank.
Old Oct 28, 2017 | 07:49 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You can use regular lead solder, or indium based
