Scan tool-code reader recommendation
Old Oct 1, 2017 | 09:04 AM
ScarabChris's Avatar
My apologies if this has been covered, I did a quick search but couldn't find a definitive answer.
I want to get a good scan tool for my 87 GTA. I have one for my other vehicles, the Innova 3100 (ABS) but it won't work for older vehicles.
What's a good scan tool for our 30 year old TPI engines? I want one that has all the bells and whistles as possible.
Old Oct 1, 2017 | 11:22 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Scan tool-code reader recommendation
Save the money and just use a paperclip. Same results.
Old Oct 1, 2017 | 01:37 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Being able to read/record/graph live data is always nice, and makes troubleshooting MUCH easier..... The snap-on MTG 2500 does all sorts of neat stuff, and you can get 'em on ebay for under 500 bucks, with everything you need, and then some..... It will work on most any car up to somewhere in the 2000s.....
Old Oct 1, 2017 | 02:11 PM
If that's your goal, then just use TunerPro. Much cheaper and gives you a lot of parameters to datalog.
Old Oct 1, 2017 | 04:32 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Tunerpro rt is a great tool. It can be a real bear to connect to the op 1227165 ecm.
Old Oct 1, 2017 | 05:29 PM
Yeah...not a helpful response for someone looking for honest and genuine help. Maybe the "use a paperclip" response is a common running joke but I don't get it. I really have no idea what that response even means. I seriously have no clue what "use a paperclip" means even in the joking format.
Old Oct 1, 2017 | 05:30 PM
Thank you....this points me in the right direction.
Engine: Lb9
Transmission: M20
A paper clip can be used to read the codes with the check engine linger. Jumper the aldl connector at the drivers knee level a to b.
https://www.obd-codes.com/faq/read-g...codes-free.php
Old Oct 1, 2017 | 05:34 PM
Gotcha...but I mentioned "bells and whistles" in my post. That means I want to plug a device in and have it tell me the codes. I don't want to count engine light blinks.
Old Oct 1, 2017 | 05:35 PM
Engine: Lb9
Transmission: M20
You can ad a bell or whistle to the paper clip lmao
Old Oct 1, 2017 | 06:00 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
If you just want to read codes this guy will work. They
https://www.summitracing.com/parts/a...MobileSwitchNo
More info
https://actron.com/content/autoxray-...ii-code-reader
Autoxray makes several readers scanners that are OBD 1 and 2 useable. I have there ezscan 6000 but they don't make it anymore
Old Oct 5, 2017 | 10:43 AM
Peter Bowen's Avatar
I JUST went through this. I ended up building my own cable and using a computer with WinALDL and TunerPro RT. The cost was much less than a scanner, and I'm getting all of the data.
I think most people just use the computer solution.
Old Oct 5, 2017 | 12:00 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Link to thread https://www.thirdgen.org/forums/diy-...ging-live.html
Old Oct 5, 2017 | 12:04 PM
W.E.G.'s Avatar
Engine: V6 2.8
paper clip method
Start video at 5:10 if you don't want to listen to five minutes of me babbling to get worked up for it.
Old Oct 5, 2017 | 03:26 PM
ULTM8Z's Avatar
Agreed. Tunerpro is the way to go.
Old Nov 15, 2017 | 09:36 PM
Claudioa's Avatar
An old snap on scanner will do the trick
The 2500 also called the brick....... look on eBay and offer up and let go
A good used one can be found for like $200. You can also scan other old cars if you find a complete one.......
Check local auto parts store they have some OBD I scanners
Also can get an adapter cable and use a OBD II scanner...
I can put a old school whistle on a paper clip...... lol
Sorry just had to........
Old Nov 18, 2017 | 03:36 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Amen to that. I can get WinALDL to hook up just fine. Never could get TunerPro rt to hook up no matter how many times I try.
Old Nov 28, 2017 | 08:33 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
LMAO!
(pulled a d3mn code 36 tonight, I FKING KNEW IT!)
