Bent runners
Old Nov 1, 2017 | 01:22 AM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
Bent runners
I just got a 85 z28 with a 305 tpi and I was wondering if this will affect anything
Old Nov 1, 2017 | 08:34 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Bent runners
It will effect airflow, not sure of how much. They make "*****" that you run through them to pop those dents out. Try Fleabay under "Runner dent removal"
https://www.ebay.com/itm/2-TUNED-POR...021412?vxp=mtr
Old Nov 1, 2017 | 09:38 AM
Re: Bent runners
Okay thanks. Its not bent to much just reminds me of a banged up header so I don't think it will affect it to much
Old Nov 2, 2017 | 05:57 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Bent runners
I hate seeing that people dont take care of their things.
Old Nov 2, 2017 | 06:42 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Bent runners
You need to grind down the inner lip before using the ball bearings.
Old Nov 2, 2017 | 09:43 PM
Re: Bent runners
Thanks I'll probably just leave it how it is for now
Old Nov 3, 2017 | 05:35 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: Bent runners
They are easily replaced...
Old Nov 5, 2017 | 05:27 AM
RRustenholtz's Avatar
Car: 1985 Camaro Iroc Z28
Engine: 305 5.0 TPI
Re: Bent runners
It really makes you wonder how it got dented in the first place. Prolly pissed off the old lady and she took the 5lb hammer to it haha.
Old Nov 5, 2017 | 11:52 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Re: Bent runners
They appear to be so thin that even if someone drops their 3/4 ratchet on them from 1 foot high itll dent. They could have gotten damaged in shipping. Or someone, while installing/removing the tubes, moving back and forth from the engine bay and in a hurry, turned around and smacked a tube.
Old Nov 12, 2017 | 07:39 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Re: Bent runners
Here are some for you. Look brand new
https://www.ebay.com/itm/1985-88-CAM...0/391880120852
