Crank but no start
Old Nov 10, 2017 | 10:14 AM
faisal's Avatar
Crank but no start
Can any please list the couses of crank with no start...have this 91 TPI bird that drive me crazy ,New sparks new fuel pump and still ..
Old Nov 10, 2017 | 10:39 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Crank but no start
Do you have spark, fuel pressure is ? Injector pulse ?
Old Nov 10, 2017 | 10:56 AM
faisal's Avatar
Paper clip trick also not showing any codes.
Old Nov 10, 2017 | 11:07 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Do you have spark? fuel pressure is? Injector pulse?
Old Nov 10, 2017 | 01:00 PM
faisal's Avatar
Do i have spark...yes.
.puls..pressure.. i dont know..don't have the equept to make sure
Old Nov 11, 2017 | 11:59 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
can you hear the fuel pump when you turn the key?
Old Nov 11, 2017 | 12:03 PM
faisal's Avatar
Yes , it gives a sound for like 3 seconds than sound goes off .
Old Nov 11, 2017 | 12:21 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
How do you know for sure you have spark?
If these cars are like the trucks, then the oil pressure sensor must read a good pressure otherwise it wont power the fuel pump after the prime when you try to start. Are you sure you are full on oil?
Old Nov 12, 2017 | 12:42 AM
faisal's Avatar
Oil is OK.
Old Nov 12, 2017 | 12:56 AM
faisal's Avatar
I suspect that the fuel pump is not the right one , parts shop gives me this 305 1991 caprice classic saying all are the same , maybe the pressure is not enough.. with note that after it fire up very well , than second day it wont again.
Old Nov 12, 2017 | 01:25 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
A 91 caprice with a 305 was a TBI, so your TPI would be getting max 15 psi.
From what I have read here, a TPI needs around 30 to at least idle, and 40-45 to be able to drive properly. The unit I put on my truck came set at 45. I havent yet measured the car but I would assume its around the same.
Old Nov 15, 2017 | 12:29 AM
faisal's Avatar
SOLVED , poor previous fuel pump has reassemble again , and WALLA car starts. thank you all you were so helpful.
