good ol tpi electrical problems.
Car: 85 Trans Am
Engine: 5.7TPI
Hey guys
Ok so I've swapped a 91 L98 350tpi into my 85 trans am which had the 305LB9. There was a ton of re wiring and pin out changes and running the 91 pcm. Car runs and drives great. Only issue I'm having is if I shut the car off when warm and restart it. I think the computer keeps doing a re learn cause it idles sporadic and sometimes dies. I've changed TPS, IAC etc and leads me down to something not giving the computer constant power to keep its memory?? Maybe?? . I am by no means a pro with all this computer crap and was wondering if someone can help me out with where that wiring should be going? Or how’s to solve this problem
Car: 85 Trans Am
Engine: 5.7TPI
Re: good ol tpi electrical problems.
only on a warm restart. for some reason at dead cold it runs great. say i need to get gas and shut it down. when i restart it, it will surge on idle. stopped at a red light it will surge and may or may not stall out. its kinda strange
everything about the engine and chip is stock?
Car: 85 Trans Am
Engine: 5.7TPI
okay! how do i go about solving that problem? it does have a performance chip but chip in or out it does the same thing. no major upgrades other than injectors,headers, minor tweaks here and there. it was a fairly extensive pin out and electrical change that was done. (fairly extensive more me anyways)
You may have issues with the voltage offsets in the calibration. Do a search on Bosch-III.
If true, at worst you' require a calibration change to correct, at best maybe a tweak of the fuel pressure.
are you able to take data with tunerpro? Or at all,
CarAteMyMoney
Jun 22, 2003 10:31 PM
jjg
Nov 19, 2002 08:00 PM
