Hi Can you install the l98 engine inteik manifold on the engine for 305 tbi
Car: 1991 Z28 1LE
Re: Hi Can you install the l98 engine inteik manifold on the engine for 305 tbi
Yeah you can put the TPI intake on your TBI engine without changing the cylinder heads. You'll need to change the wiring harness, ECU, Fuel pump, and if you have an automatic trans the TV kick down cable.
I want to install it on the 305 TBI engine
https://www.ebay.com/itm/1986-Corvet...-/391431742729
https://www.ebay.com/itm/162807902829
https://www.ebay.com/p/1989-1991-Cor....c100005.m1851
https://www.ebay.com/p/85-Corvette-T....c100005.m1851
What is the difference between them I want to install on the TBI 305 engine
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the 87 up intake will be a direct bolt on. If you get a 85/86 base you will need to elongate the center 4 intake holes.Vetted bases used a coolant crossover and were the old 90 degree bolt pattern vs 72 I think it is for the 87 up. Performance bases have both patterns drilled into them Accel edelbrock tpis .
jay173
May 26, 2010 08:38 AM
86z/92rs
Jan 3, 2005 09:01 PM
