MAF sensor which one?
Old Feb 1, 2018 | 01:31 PM
dmm3369's Avatar
Car: 83 Z28 / 89 IROC
Engine: 350's
Transmission: T5 WC / 700R4
Axle/Gears: Posi 3.73
Been reading through all the MAF discussions and see 85, 87 & 88 and 89 could use different version. Which one if you had an 89 TPI L98 engine would you buy if you could only buy one? I have purchased 2 and the 189.00 Orielly one ran terrible black smoke you name it. The cheap 85 dollar one almost works but has code 33.
I know there are many discussions about this even for vettes.
I am about ready to carb the thing....
David
Old Feb 1, 2018 | 01:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: MAF sensor which one?
The 85 is digital and won’t work properly iirc.
It’s very odd you have a maf high error with 5gps at idle.
Vader would be the go to guy to ask which maf to get.
I would look in the classifieds for someone parting out a 86-89 and get a used Bosch unit.
There are a few different part numbers but as far as I know the function the same.
Old Feb 1, 2018 | 01:45 PM
Engine: Lb9
Transmission: M20
The code 33 maf threashold can be changed in the tune . With low Maf at idle it’s hard to believe your hitting the 1/4 Throttle threashold.
https://www.thirdgen.org/forums/tpi/...de-33-maf.html
Old Feb 1, 2018 | 06:36 PM
dmm3369's Avatar
Engine: 350's
So far with the new chip and ECM its cleared. Also replaced the MAF relays. I put about 30 minutes on the engine and no codes yet.
Fire"Dutch"Bird
May 8, 2014 01:03 PM
87hellbird
Apr 1, 2013 09:20 PM
blue86iroc
Mar 16, 2003 04:48 PM
