Adjusting MAF tables due to MAF sensor modifications
Old Mar 14, 2003 | 10:51 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Before I knew about PROM burning, MAF tables, etc., I (probably stupidly) removed the screens from the MAF sensor on my car. Now, I know that it isn't calibrated properly because of the change in airflow. I read Grumpy's article about recalibrating the MAF and also his article on the GN site, and I have two questions.
1. Can I save this adjustment for later? Meaning, can I get the car running where it should be (~128 BLMs) and then tinker with the MAF tables, or will it throw off my previous tuning?
2. Based upon the articles, it seems like tuning the MAF is a guess-and-check method. Is this correct?
Old Mar 14, 2003 | 03:40 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Adjusting MAF tables due to MAF sensor modifications
1) If you make no intake tract, or cam changes the MAF should be close.
2) Guess and check without a WB. Having a WB makes it MUCH easier.
Old Mar 14, 2003 | 10:59 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Decrease your FI constant by 10% or so. That'll take care of fin & screen removal right quick. Later on you can get into the MAF tables & do it right...
Old Mar 15, 2003 | 07:16 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<sigh>
What's wrong with just doing it correctly?.
Every notice LONG TERM, that the quick fixes, aren't?.
For the time spent fooling with wrong items, that time could be spent on working on the correct items, and save dong things twice.
Tuning is about habits.
Get into the wrong mind set, and you can waste a whole bunch of time walking around in circles.
In a way Correct Tuning is a form of Zen. You really have to clear your mind, and just do what the engine's telling ya. Take your notes, and look for trends, get that down, and it gets MUCH easier and faster.
blue86iroc's Avatar
Car: 1986 IROC-Z
Thanks for replying, Grumpy and Craig. I really do need to build a WB if I plan to seriously get into chip burning. Craig, I've only removed the screens -- I haven't touched the MAF fins. With that in mind, would I still take the FI constant down a full 10% or more like 5-7%?
Old Mar 15, 2003 | 09:09 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Grumpy, it looks like we both replied at the same time so I didn't see your second reply until now. After reading your post and thinking about it, I see that changing one thing to compensate for another (FI constant, in this case), would still negate some previous tuning once I get to the MAF tables.
Old Mar 15, 2003 | 09:52 PM
Car: 87 T/A
Good point... Keep forgetting that while it might get me by, it will serve to confuse others...
Old Mar 16, 2003 | 11:51 AM
funstick's Avatar
got a question for grumpy.
aside from actually messing with the maf. BS'ing the injector constant is really so bad ?? i dont see how. if the corrections are correct for the engine in question then changing the inj constant will have a global effect on fueling. it also means that all calculated values will follow the same slew.
Old Mar 16, 2003 | 04:48 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not Grumpy, but, there is more then just the BPW calc being tied to the airflow term. By changing just the injector constant all the other calcs that depend upon the true airflow are now skewed.
RBob.
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
perZ
Aug 15, 2015 01:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
