Fuel Pump Replacement?
Old Feb 27, 2018 | 07:24 PM
JuanZ28's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 5.7 TPI
Fuel Pressure is at 40psi with ignition switch on and it drops to Zero PSI fast. When engine is running PSI stays at 35 and when I idle it jumps to 41psi.
Symptom that car has is that it stalls for a couple of seconds when I hit the throttle then it picks up. Could it be a bad fuel pump or should I rule out any other parts?
Thanks.
Old Feb 27, 2018 | 09:31 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Fuel Pump Replacement?
When you say it stalls for a couple of seconds when you hit the throttle, does it do it when cold or when warmed up (or both)?
Old Feb 28, 2018 | 07:37 AM
JuanZ28's Avatar
Engine: 5.7 TPI
Both when cold and hot.
Old Feb 28, 2018 | 06:21 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Well dropping PSI immediately after the pump turns off is concerning. Its probably running rich but having scan data would be nice. You should try and find out where the fuel is going when pump is off. Here's a pretty good demo of how to do it, but you can come up with your own way.
Old Feb 28, 2018 | 06:37 PM
JuanZ28's Avatar
Engine: 5.7 TPI
Thanks Pro
kowboy59
Nov 7, 2011 09:36 PM
kowboy59
Apr 30, 2008 05:30 PM
makinemtap
Jan 30, 2002 01:09 AM
442guy
Apr 13, 2001 04:58 PM
