Better grounds solved random idle drop and die issue
Old Mar 19, 2018 | 09:27 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Just passing along, I had a random at-idle engine drop out/die issue. About once a trip around town.
I added new ground paths (#12 THHN house wiring, stranded) for the engine to the body and another 8 AWG bond from the right fender to the battery.
I tied the the O2 sensor housing to ground with a hose clamp holding the stripped wire to the housing, a water pump bolt, and an intake manifold bolt - each with a dedicated ground to the body.
I added a dedicated ground to those major pieces that had sensors mounted in them. The water pump bolt was my way to get to the engine block itself (those bolts/threads had been cleaned recently).
In addition to the single action of adding grounds and the idle die problem never coming back after that, the gauges seem to be more solid as well and the engine "seems" to run more smoothly.
Old Mar 19, 2018 | 10:11 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
Re: Better grounds solved random idle drop and die issue
Interesting. Did you replace the OE ground wires?
Old Mar 20, 2018 | 10:52 AM
ULTM8Z's Avatar
Yeah, I have grounds all over the place. The engine did seem to run noticeably better after doing that.
Old Mar 30, 2018 | 01:56 PM
Engine: 350 TPI L98
Transmission: WC T5
I did not replace the exiting ground cables at the battery. They looked good. I did clean them up at the their contact points. I could not get to the ground straps at the back of the block so I left them in place.
white_ghost
Oct 22, 2012 11:49 PM
91NiteRida'
Jan 23, 2004 10:29 PM
Xceleratemaro
Aug 19, 2003 11:59 PM
