best distributor
Old Apr 10, 2018 | 07:58 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Engine: 90-95 ZZ4 Crate 350 TPI
Transmission: 700R4 4spd Automatic
Axle/Gears: 3:73
best distributor
Just completed 305-350 swap and want to know the best distributor to use
Old Apr 11, 2018 | 12:15 PM
BOTTLEDZ28's Avatar
Transmission: A4
Re: best distributor
The stock one assuming its in good working order.
Old Apr 11, 2018 | 12:41 PM
ULTM8Z's Avatar
Agreed.. stock with a good coil works just fine.
Old Apr 11, 2018 | 12:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The other choice is a msd, there icm s are pretty cheap so if failure occurs use a 369 gm icm.
Old Apr 11, 2018 | 01:04 PM
firebrdo88's Avatar
Car: 1988 Pontiac Firebird
Engine: 400 sbc
Transmission: TH400
Axle/Gears: Ford 9" 3.50 35 Spline
I will be that guy.... The best distributer is none. I love my 24x swap.
Old Apr 11, 2018 | 08:14 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
OK.
Lots of good ideas...so the stock style I need to use (due to my wiring harness being a MAF system) is the 305. It'll be a brand new one, since the older one had 89K on it. Also following the Comp Cams shopping list, I purchased the 12200 gear that'll replace the stock gears at the base. Then with the distributor cap, You guys are suggesting a MSD set-up. Now as you guys know, the coil isn't external like the 350, the coil is integrated in the cap. What your recommendations for this conversion or is it dirt simple. Order the MSD cap with a integrated coil (if it all possible) do I have to change the guts out like one of the other guys said...
Thanks for your time.
Old Apr 11, 2018 | 08:17 PM
Engine: Lb9
Transmission: M20
with her coil in cap you should have 4 screws holding on the cap unlike non cc that have 4 arms that swing to retain the cap.
https://www.ebay.com/itm/Accel-8131-...NSWwgB&vxp=mtr
Old Apr 11, 2018 | 09:01 PM
Drew's Avatar
You can always convert to the divorced coil distributor from an 87-92 car. It's a really basic cut/splice the old distributor harness to the new one. Much easier to find, more options for service parts, etc.
Old Jul 28, 2018 | 05:24 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Thanks for all the guidance...I went with the stock distributor and coil pack. everything is brand new...runs like a champ...
Old Jul 28, 2018 | 08:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yep, my original response to your question was to use stock distributor. Glad to hear that you did that right off.
RBob,
Old Aug 3, 2018 | 11:10 AM
Engine: Lb9
Transmission: M20
was the distributor the source of your running issue ?
midias
Jan 28, 2017 11:19 AM
NJChris
Jan 22, 2017 10:48 PM
zapc
Jan 11, 2017 06:45 AM
whatdo
Oct 15, 2016 01:58 PM
Dracula
Oct 10, 2016 06:41 PM
