1990 iroc misfire
Old Apr 27, 2018 | 04:14 AM
frostedmonster's Avatar
1990 iroc misfire
Code 42,44 car is misfiring and when you rev it the let off and try to rev again it won’t... just bogs and hesitates like crazy. Car doesn’t seem to rev higher than 3500 rpm
new parts
distributor
iac
icm
coil
wires
plugs
coolant sensor
And fuel pressure is 42 when key on. Idle is 38 and when rpm goes up fuel pressure is 36-42 area moves around a bit
timing is set at 6 degrees .
Old Apr 27, 2018 | 05:26 AM
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
Re: 1990 iroc misfire
https://www.thirdgen.org/forums/elec...l#&gid=1&pid=1
Found searching
Might be helpful
Old May 6, 2018 | 12:38 PM
Thank you it ended up being my ecm !
GageBrand
Jul 3, 2013 02:58 AM
GageBrand
Jul 1, 2013 02:31 PM
spitfireIX
Apr 22, 2013 03:57 PM
R/T-Z28
Feb 17, 2013 12:08 AM
IROCAZZ
Camaros Wanted
Jan 21, 2008 06:30 PM
