Timing question
Old May 4, 2018 | 12:38 AM
Adrian2898's Avatar
Car: 1989 camaro iroc-z
Engine: 350 tpi
Timing question
So I took my 89 350 tpi to get the engine rebuilt and I decided to install a bigger camshaft. When I went to pick up the car it was running rough, it would turn off at light or when i put it in gear. I had a mechanic look at it and he realized that the distributor was loose and the timing was off. He tightened it and put the timing to stock set up but now when I turn it on it idles at like 2100 rpm and when I shift it to drive it idles at 1300. Will I have to adjust the timing a bit because of the bigger cam? Thanks
Old May 4, 2018 | 11:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Timing question
You might try 6-8 with the est disconnected. You can always have it advanced more with a custom tune for the cam.
Don 79 TA
Apr 30, 2006 03:50 PM
BOSS 357
Dec 18, 2005 12:43 PM
pauls
Jan 24, 2002 09:47 AM
colincamaro
Jun 24, 2001 06:38 PM
MikeH
Jul 31, 2000 12:26 PM
