Car running too cold
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
91 GTA 5.0 TPI doesn't get warm according to her guage... I replaced the thermostat and cooling sensor a couple years ago. The car is idling a little high bc of this as the computer seems to be giving the car more fuel.
any ideas? maybe the thermostat is stuck open?
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: Car running too cold
Have you attempted to measure the temperature externally, via an infrared thermometer or even by hand (don't burn yourself though)?
Could be the temp gauge sender, too.
Engine: V8 305
i never changed the temp gauge sender.. I might try that.. im not sure if I have a infrared termometer
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
How long are you running it, I know mine takes what seems like a long time to get to operating temp.
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
When I first got my 88 IROC Z it was drinking gas, would not warm up. Would only warm up a little if I sat at a stop light. Thermostat was stuck wide open.
Engine: V8 305
I got a smell of gas around my car with no visible leaking... the car doesn't warm up at all, no matter how long I lets her warm up.
Car: 88 IROC-Z
Best way to see what the engine is seeing is to connect a reader. Run to a parts store and have them plug in and check the reader to the gauge,
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Do you get coolant flow cold ?
You can remove the radiator cap and watch flow.
Engine: V8 305
Engine: Lb9
Transmission: M20
If the cooling is flowing when the engine is first started up I would think the thermostat is stuck open.
Engine: V8 305
changed thermostat... seemed to fix it.. now I got a coolant leak.. something must not be tight enough.
Birdstheword
Jan 5, 2012 03:34 PM
