Dual Cooling Fans ??
Old Jan 5, 2002 | 10:59 PM
StocRoc's Avatar
I have an 86 Iroc w/ the single electric fan, and I want to upgrade to the dual cooling fans that came w/ the 350. If I find a 350 donor car, what all do I need to take?? Just the fans, of do I also need the upper and lower fan shrouds?? And will one from a TPI Trans Am work in a Camaro?? Are they the same?? How much cooler should this make my car run???
Old Jan 5, 2002 | 11:17 PM
87transam5.7tpi's Avatar
switching to the dual fans won't make your car run cooler until they kick on, which is 225 degrees in our cars. what I just did was put in a 180 deg. thermostat and got the jet fan switch from summit racing for about 38 bucks. that was the best $50 I've spent on the car so far. the fan switch will kick on at 200 and shut off at 185. I would try that and see if you car runs cooler before you spend all the time and money switching to dual fans. and I have dual fans on my trans am and the second fan never turns on until I use the a/c anyways (which I never do). so I would go with the thermostat and the fan switch. its a good $50 spent. I'd recomend it to anybody!
Old Jan 6, 2002 | 01:07 AM
karfreek's Avatar
Drivers Fan kicks on @ 225, Passengers @ 235. Both kick on for me, Talk about Voltage Drop ! When my A/C is on the Passengers is on almost all the time.
Jay
Old Jan 6, 2002 | 10:49 AM
Gta-Paladin's Avatar
is running dual fans with pully's a bad idea?
Are the power pully's at all that good? Do they actually maintain good drive to the alt?
Old Jan 6, 2002 | 01:30 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I'm running quad fans. Two in front and two behind the radiator.
Cools pretty good. They are set to come on at differant times.
codeysabatini
Nov 10, 2015 04:07 PM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
