305 tpi wont start
Old May 17, 2018 | 10:16 AM
Demiks's Avatar
305 tpi wont start
After a good ride about 15 minutes, i was going to ride again my -88 iroc, it started well but after some seconds shut down and wont restart.
i checked if there goes electricity to fuel pump (exterior, changed from original) and showed zero volts.
What should i do next? is there a way to skip the relay to see if that is the problem?
Old May 21, 2018 | 08:05 PM
89iroc_lb9's Avatar
Car: 89 iroc
Engine: LB9
Axle/Gears: 2.72
Re: 305 tpi wont start
spray brake cleaner through throttle body see if that starts it also with no power to the pump make sure the alarm isnt tripped if it has that and i would see if you can trace the wires to see if there is a kill switch relay for it
camarors1989v6
Oct 9, 2009 06:25 PM
camarors1989v6
Sep 8, 2009 01:43 PM
Birdsong_'89_RS
May 6, 2008 10:01 PM
84TAProject
Jan 9, 2003 07:29 PM
TPI K5
Aug 9, 2002 05:00 PM
