My car wont start it wont even turn over.
Old Sep 5, 2009 | 04:56 PM
camarors1989v6's Avatar
I have a 1989 5.0 l that wont start. Ive juat replaced the starter and battery but nothing happens it wont even turn over. Electricity does seem to reach the starter but nothing happens not even a click. Its missing various fuses including the crank fuse. Can anybody help me out pls. When i turn the switch all other components come on but the car just wont start. Thanks for any answers.
Old Sep 5, 2009 | 05:14 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: My car wont start it wont even turn over.
Well if you have missing fuses, make sure they are all in and replace the burnt ones. Make sure you test or replace the main fuses if any. Also you should try jumping the posts on the back of the starter. if the engine turns over, then your starter solenoid is bad. Also check to see if your ignition switch is making the proper contact to engage the starter.
Old Sep 5, 2009 | 05:56 PM
topfile's Avatar
I think the Crank Fuse is 3 amps. To activate the solenoid circuit the
Clutch Switch or Gear Selector Switch that needs to be on.
So it must be in PARK or Clutch depressed to start I believe.
If one of those switches is busted then no start.
Also the Starter Enable Relay must be on.
Old Oct 9, 2009 | 12:21 PM
beat91rs's Avatar
Your saying when you jump the starter and it turns over the solenoid is bad? Wouldn't this mean it is good?
Old Oct 9, 2009 | 06:20 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
VATS
Old Oct 9, 2009 | 06:25 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Correct if you hotwire to the starter solenoid terminal , not the main post on the starter itself. If it will turn over when you jump the solenoid, it means battery / starter / solenoid are good. If it won't turn ;then could be starter /solenoid/ cables / connections or grounds faulty.
You are not getting power to the solenoid.Could be any one of the items mentioned above.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 17, 2015 02:00 PM
djmarch
Aug 9, 2015 05:27 PM
