Code 43
Old Jun 16, 2018 | 09:07 AM
Chiknhawk's Avatar
Code 43
I have recently stated getting CEL on hard acceleration. I've checked the codes and get a 43 code. What are your suggestions as where to start. Car is an 88 5.0 TPI.
Old Jun 16, 2018 | 09:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Code 43
Sounds like the forced knock test is failing. Does the engine ping when you do the hard acceleration?
If not the base timing may be off, or you are using fuel with too high of an octane.
RBob.
Old Jun 16, 2018 | 04:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code 43
Here is a flow chart for code 43
http://www.chevythunder.com/maf_esc_module_code_43.htm
Old Jun 16, 2018 | 09:13 PM
Chiknhawk's Avatar
Re: Code 43
Thanks Man. I'll get on it in the morning.
sqzbox
Sep 28, 2003 10:03 PM
KED85
Feb 13, 2002 10:07 AM
Jax86SC
Jul 2, 2001 10:17 PM
Black Beauty
Jan 7, 2001 08:46 AM
Christos
Nov 17, 2000 05:23 PM
