No power to fuel pump pin D c207 connector 87 iroc harness
Old Jul 11, 2018 | 08:29 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Hey all,
I'm installing an 87 iroc body and TPI engine harness in a 91 Z28.
everything seems to be working except I get no power to pin D of the c207 connector for the fuel pump. On the body harness side of the connector is a brown 10 gauge wire and on the engine harness side of the connector is a 10 gauge Tan/why wire.
This wire Powers the fuel pump relay while ECM I believe switches the relay on but without power that relay does nothing.so I get no pump prime.
I'm having a hard time tracing the pin D brown wire back to its source of power. Any help would be appreciated. I think it goes to the injector to fuse at the Box supposedly but I can't seem to find continuity between that wire and the fuse box.
This could just be a misconnected wiring harness or something like that but I am at a loss presently.
I should be able to figure it out when I get the service manual books on Friday but in the hope of figuring out sooner I thought I'd reach out to the hive mind here at TGO.
Thanks.
Old Jul 11, 2018 | 12:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: No power to fuel pump pin D c207 connector 87 iroc harness
I think the power for the fuel pump relay is the red wire by the battery protected by a 20 amp fuse.
The splice also feeds the ops.
Old Jul 11, 2018 | 05:38 PM
Engine: 383 HSR EBL
You were spot on Tuned Performance! Turns out I never hooked that circuit to power, so the entire engine was without power. Thanks!
Old Jul 11, 2018 | 06:19 PM
Engine: Lb9
Transmission: M20
Glad you got it, hope you get the valvetrain figured out soon.
Old Jul 11, 2018 | 06:56 PM
Engine: 383 HSR EBL
Aye. Just need to wait on a shop to have time for the valve train.
Old Aug 9, 2019 | 06:12 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
n/m
BigRogZ28
Apr 28, 2011 11:08 AM
Brisco
Aug 16, 2007 10:31 PM
ffvetteman
Aug 27, 2004 05:54 PM
9D1BURD
May 26, 2004 11:17 AM
