Tip swap idle problems
Old Jul 22, 2018 | 01:02 PM
bowtied_gta's Avatar
just wrapped up my tpi swap, car is a 90 formula originally tbi. Used an unmolested engine harness from hawks.
Car fired right off, I set base timing at 6 degrees with the est bypass disconnected at the firewall, all is fine.
Shut the car down, wait a few minutes, reconnect the est bypass and fire it off and the car immediately goes to 3500rpm and stays there. It’s throwing a ton of timing at it as soon as I give the ecm control of the timing again. Any suggestions? I’ve ruled out iac, I can close it manually and leave it unplugged and it still skyrockets in rpm. Car had a stealth ram on it, fresh iac, tps, etc. thanks in advance
Old Jul 23, 2018 | 03:37 PM
86IROC112's Avatar
Car: 1986 IROC Z
Re: Tip swap idle problems
Vacuum leak??
Old Jul 23, 2018 | 08:04 PM
Originally Posted by 86IROC112
Vacuum leak??
you nailed it. Forgot to post an update, I bought the HSR used and assembled from a local guy who couldn’t get his car to idle. Figured he had tuning issues. I pulled the plenum to reseal it and found there’s a vacuum port in the middle of the plenum, on the bottom. It was wide open....put a 3/8” npt pipe plug in it and all is well!
Old Jul 23, 2018 | 08:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Isn’t that for the iat/mat ?
Old Jul 24, 2018 | 06:59 AM
firefox7518's Avatar
Car: 1989 TransAm GTA
Engine: 350ci
Transmission: TH700
Axle/Gears: Stock 9-bolt
yep Tuned Performance, normally it goes into that spot.
Old Jul 24, 2018 | 02:22 PM
I’ve relocated mine to the intake piping with the v6 iat sensor. Didn’t even think to check the bottom of the plenum before putting it on the car. Stupid mistake!
Old Jul 24, 2018 | 02:25 PM
Engine: Lb9
Transmission: M20
You should tune for the iat relocation
https://www.thirdgen.org/forums/diy-...at-lookup.html
Old Jul 24, 2018 | 03:17 PM
Thanks for the heads up. I’ve been working with Scott Hansen on the base tune, going to do some logging and have him finalize it. Then I’m on my own, this is a little 355 blower motor with a vortech Head unit. Going to hack around it for now, picked up a 6btm and an fmu. Will be temporary until I make sure the car works and then I’ll probably do one of the efi connection setups and an lsx ecm. I already have hp tuners for my ls stuff, just didn’t want to invest much into hardware in tuning the sbc not knowing if it’s going to stay in the car or not. Was one of those things where I blew it up but was so deep into the small block setup I stayed with it for now. Actually traded my blow through 750 for the whole stealth ram setup, harness was $300, figured it’d be cool to have all my factory stuff work again. We’ll see, may even keep the 730 in it if it doesn’t throw a fit with 7 pounds on it. Just have to fool the map one way or another, probably with a temporary hack job check valve haha
ULTM8Z
Jun 5, 2015 07:42 AM
84Elky
18
Dec 5, 2012 10:18 AM
shane_429
Sep 28, 2010 09:38 PM
fsted
Oct 9, 2006 06:09 PM
