Backfire Issues
Old Oct 1, 2018 | 10:15 PM
Herriott88's Avatar
Backfire Issues
I own a 1991 305 tpi 5 spd. manual and im having issues with backfiring. Ive set the timing anywhere from 0 to 6 degrees before tdc and get same results and ive made sure to disconnect the wire, replaced spark plugs (noticed there was blow by on the plugs) and wires, cap and rotor as well. Ive checked for vacuum leaks and found one, fixed it and have not heard any leaks yet. What is going on?
Old Oct 2, 2018 | 06:59 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Backfire Issues
Your diverter valve is bad...
Kitten Tooth
Dec 31, 2016 04:27 PM
vorgath
Aug 19, 2007 11:48 PM
ajl'86T/A
Oct 4, 2006 11:02 PM
howell1994
May 17, 2006 08:45 AM
