Edelbrock Lower Intake install help.
Old Oct 4, 2018 | 08:58 AM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
Hello there
I currently replacing the lower intake manifold and runners on my LB9 and I'm having trouble aligning the gasket. Trying to make sure the gasket does not cover any part of the intake port of the head and the injector passage its becoming a challenge. I got the stock size from Felpro, maybe that might be the issue. I have attached a pic of the gasket showing a bit over where the injectors go. Is this normal or should I try to push it out of the way with a screw driver. Thanks
Old Oct 4, 2018 | 02:14 PM
ULTM8Z's Avatar
Re: Edelbrock Lower Intake install help.
you could either trim it or err on the side of keeping the injector unobstructed.
frankly for the useable rpm range and horsepower level of the average TPI engine, a slight overhang on the floor of the intake port isn't going to result in any noticeable reduction in power.
if I had to choose, I'd rather have a minor overhang on the intake port than an obstruction along the ineljector port.
Old Oct 6, 2018 | 08:02 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
Thanks, I took the intake manifold back out and readjusted the gasket. I went ahead and put it back on, now I have major vacuum leaks. Will try to sort it out next weekend.
Trying to install this edelbrock base and Accel runners is turning out to be some work, specially for an accountant lol.
Old Oct 9, 2018 | 09:11 PM
DD9TransAmGTA's Avatar
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
What year car do you have? Just did a edelbrock high flo and accel runners myself
Old Oct 9, 2018 | 09:12 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Did you put rtv on the front and rear of the block before you installed the intake manifold?
Old Oct 10, 2018 | 10:06 AM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
I am installing it on a 1989 LB9. I Already noticed tow issues. One, I have to block the small runner on the driver side, since is not covered by the plenum. And the other is that my injectors Southbay where too long, Already have replacement on the way. Hopefully when I put everything back on I don't have any other leaks.
Old Oct 10, 2018 | 10:07 AM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
Also I did put RTV in between the block an manifold.
Old Oct 10, 2018 | 12:03 PM
I had the same issue on my 89. I had to swap to a 85 plenum and all my vacuum leaks were gone
Old Oct 10, 2018 | 04:11 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
Thanks, For now I will try to block off the small runner on the driver side with JB weld, hopefully that will do it.
89fbirdformula
Jul 21, 2010 03:14 AM
subroc
Aug 16, 2008 07:18 AM
Black IROC
Jun 10, 2007 05:40 PM
92Z-666
Jun 12, 2006 09:14 AM
