Edelbrock/Accel Runner Installed on LB9
Old Nov 3, 2018 | 09:27 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
Hello I am posting what I think of the installation of an Edelbrock manifold and Accel runners, as a reference for anyone thinking about doing something similar. I also cleaned up a bit the manifold and plenum trying to get a bit extra flow. I will be taking the car to the track within the next couple of weeks to see the difference in Et's. Feeling for now is that the car runs stronger from about 2.5K to 4.5K, and the engine feels mush smoother as it goes through the RPM's. To my surprise the Idle quality is also much better. I am very happy with the results so far mostly because I really like the TPI setup. But for the cost and time/hassle to get them to work properly if you don't really like TPI, it might not be the best choice. Below the mod's before the installation with its respective track times.
best,14.418 @ 97.45
Edelbrock Headers
Gears 3.27
RR's 1.6
Under drive pulley's
FPR @ 48PSI
Air Foil
MsD ignition box, cap, coil etc.
Old Nov 4, 2018 | 09:48 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: Edelbrock/Accel Runner Installed on LB9
I have a new accel lower intake and ASM runners waiting for install on my LB9. I wonder if you will see some real et gain.
Justin 87 GTA
Nov 10, 2008 12:04 PM
hbranontn
Alternative Port EFI Intakes
Jul 26, 2006 12:43 PM
chevy-man77
Aftermarket Product Review
Jun 25, 2005 07:42 PM
