Engine pinging TPI
Old Dec 23, 2018 | 04:53 PM
Darren Wilton's Avatar
Car: 1988 Range Rover Classic 350 Vortec
Engine: 350 Vortec TPI
Transmission: TH400
Axle/Gears: Custom
Engine pinging TPI
I have a 350 Vortec stock with TPI speed density. Small cap dizzy with external coil
I have set base timing to 5 deg and under light throttle it pings slightly
When I floor it no ping
If I back the timing off to 2 deg it still gets slight ping
Any thought would be great it is doing my head in
Old Dec 23, 2018 | 05:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Engine pinging TPI
Have you tried your hand at ecm tuning ?
you might have to recurve your timing or add more fueling.
afpr ?
Old Dec 23, 2018 | 08:33 PM
Transmission: TH400
Axle/Gears: Custom
I have not. I have had trouble reading data via the adl port and have only had limited sucess. The problem of pinging seems to have got worse over time. What is involved with reprogramming the ecu?
Old Dec 23, 2018 | 10:31 PM
Engine: Lb9
Transmission: M20
What are you using to connect to your ecm ?
Tuner pro rt ?
To reprogram your fueling and timing tables you need to use tuner pro or tuner cat $8d mask.
You also need a burner and adapter look into moates.net g1 and burn 2.
There is a tuning guide in the diy prom section stickies to help you get started in the process.Another option would be
dynamic efi makes a great ecm add on board for your ecm. He has several starter tunes and one for vortec heads that might be a good fit.no chip swapping with the ebl flash.
Old Dec 23, 2018 | 10:38 PM
Engine: Lb9
Transmission: M20
Old Dec 24, 2018 | 02:05 AM
Transmission: TH400
Axle/Gears: Custom
Dynamic efi looks like the way to go for me I think. I've just emailed them some questions. I think that is the seasiest way to go and most effective long term. Thankyou very much for your input
pigsticker
Jun 1, 2004 06:20 PM
88TRANS
May 15, 2003 11:27 PM
Night Hawk
Nov 1, 2001 09:41 PM
Smeg
Sep 24, 2001 08:55 AM
Colin 86&87 IROC-Z
Oct 10, 2000 05:12 AM
