Brillo pads best for cleaning TPI outer surfaces? Plenum and runners off car
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Thanks in advance.
I’ve got everything apart right now, so looking for what’s best to clean oil and grease residues and general stains, thanks, what’s best?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Brillo pads best for cleaning TPI outer surfaces? Plenum and runners off car
I’ll give aluminum wheel cleaner a shot. Was thing tho, Brillo pads w steel wool might knock some stuff loose.
They are not bad, just a few stubborn spots. Thanks
Engine: Lb9
Transmission: M20
Zep 505 makes a good degreaser.
Take it to any shop with a real heated water based detergent parts washer and ask them to throw it in with their next regular load. I usually charge like $20 for this. You'll never get it cleaner yourself no matter what you use. And you can go do something more useful with your time.
Seriously cleaning parts sucks and is for suckers. About a year after I got my first real parts washer I was already shopping for a larger one. Its such a manpower multiplier and time saver it's honestly one if my most valued tools
GD
GD
Hot tank and bead blasted. Thanks for the tip!
Yep. That's how it's done.
SKFengineer
Nov 28, 2005 12:46 AM
cort351w
Jan 11, 2002 05:02 PM
